ASME Section VIII div. 1, 1989 edition
Is the requirement mentionned in paragraph UG-41(b) of ASME Section VIII div. 1 2007 was exactly the same in the ASME Section VIII div. 1 1989 edition?
Thanks in advance for your help,
hcjulien
hcjulien
RE: ASME Section VIII div. 1, 1989 edition
do you have a section number for the 1989 version?
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Joe Tank
I can only go back 'till 92 edition;- the clause UG-41(b) you mentioned has not been changed since '92 and is still valid, unchanged today in the 2007 edition. I think with some degree of confidence that this clause was also valid in '89. However, you might need a firm confirmation somewhere else...
cheers,
gr2vessels
