Welding on water filled tubes
We have welded a stringer pass (3/32)down hand on a SA210C waterfilled boiler tube with 7018A1. Single stringer about 2.5" in length. The welding was to repair an area of undercut (membrane to tube). Question is what effect on the base material and possible future failure could this cause? Our main concern would be hydrogen cracking.
Thanks in Advance.
Thanks in Advance.
RE: Welding on water filled tubes
