unload file/part from catia session
Is there a way to unload a file/part from catia so the file can be replaced without shutting down catia. In solidworks if you use: (file-close) from the pull down menu the file is closed and unloaded, if you just close the file by clicking on the x box in the upper right the file closes but is not unoaded from the session and can not be replaced. This doesn't seem to be the case with catia?
RE: unload file/part from catia session
If you are working in an Assembly you could use the Contextual menu --> Components --> Unload button.
You should have the top of the assembly active for this.
Derek
if you want to replace it, there is also a replace feature in assembly context
Have you tried using the desk unload/load?
In my experience, if you "unload" the part, the memory used by Catia is not going down. (memory leak)
Therefore, I am shutting down catia every two hours.
