MSC Nastran - how to enable NX to use MD Nastran
In the ugii_env.dat file, there are 2 variables that can modify the MSC Nastran location and version.
The version variable comments:
"UGII_MSC_NASTRAN_VERSION sets the MSC NASTRAN version number of the solver. Valid versions are 68 for 68.2, 69, 70, 2001, and 2005. This environment variable allows the authorization to work on various versions of MSC Nastran. If you are using another version besides 2005 you must set this variable for the appropriate version."
What about the more recent MD.Nastran versions (ie MD.Nastran R2.1, R2.2, or R3)?
Are these versions supported?  If so, what changes should be made to ugii_env.dat to enable them to be used?
