SolidWorks 2009 Beta 1 and SolidWorks Pack & Go error
I tried to install SolidWorks 2009 Beta 1 but the same would not work on my system. I asked my reseller and he told that it will not work on a system already having any version of SolidWorks. I tried uninstalling the same but I am unable to do so. It gives an error:
"Error 1722. There is a problem with this windows installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action Unregister_i386_SldSheelExtServerExe, location: C:\Program Files\SolidWorks 2009 Beta 1\sldShellExtServer.exe, Command: sldshellextserver.exe /UNREGSERVER"
I had SW 2007 & 2008 on my system. I uninstalled these and tried but still get the same error. I have removed all related registry files but what ever I do I am unable to uninstall SW 2009 Beta 1. The error 1722 persists.
I have now installed SolidWorks 2008 SP4.0
When I try to use Pack & Go, I get an error "Could not load SolidWorks DLL"
Is there any solution for this? Any help is highly appreciated.
RKam
RKam
RE: SolidWorks 2009 Beta 1 and SolidWorks Pack & Go error
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://designsmarter.typepad.com/rob_rodriguez/
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
I feel like doing that many a times!!!
At present I am unable to install SW 2009 plus it is also affecting my SW 2008! I am unable to use pack & go and I don't know what other problems I will come across.
I am also not sure if this is windows xp related or SW related. The error of course shows this as SW registry problem.
At present I have wasted lots of time and energy on this. Final option would be to format the drive & reinstall windows xp. Then reinstall SW fresh.
RKam
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
