Creating surface from measured points???
Is there any possible way to import a measured set of data X,Y,Z, by using a cmm , in order to costruct a surface.
My inspection conducted on a casting part and i want to visualize my results.
Thanks in advance.
Jim
Thanks in advance.
Jim
RE: Creating surface from measured points???
http:
There are other scripts out there. Search points from excel.
Derek
but there was an error, and for god shake written in german!!!
If you want to check the result of the CMM... you can directly compare the cloud // your solid using "Distance Analysis"
