selecting dimensions for editing
I have been a SE user for a no. of years and I haven't figured out this problem. When I am modifying a dimension of a feature it takes a long time to select desired dimension. Even if the dimension is the only one displayed and no other features are in the way I have to hover over dimension or re-orientate part.
I must be doing something wrong.
Is there setting or hot-key I should be using?
I normally select feature and use "Select tool - dynamic edit"
