does anyone have clues about M50 VIM-Var corrosion behaviour
Hi everybody,
Everything in the title of the post: does anyone have clues about M50 VIM-Var corrosion behaviour?
I'm looking for some data on the corrosion of this alloys in ambiant environnement (air) for bearings (without oil) at 300°C. Do you think it will be appropriate or I need to switch for an inox (in term of corrosion).
Bearing will not be use really often (only emergency bearings).
Thank you for your help...
RE: does anyone have clues about M50 VIM-Var corrosion behaviour
How is the bearing loaded and how bit is the load?
Is there any vibration?
Can you possibly put a dry film lubricant on it?
