What's the effect of SO3 (sulfur trioxide) on Sulfuric acid corrosion?
I'm looking for the data of the effect of SO3 (sulfur trioxide) on Sulfuric acdid corrosion.
I found a graph (from NACE Corrosion Engineer's Reference Book) about calculated sulfuric acid dew point in flue gas vs. sulfur trioxide corrosion in 10% water.
And this graph showed that dewpoint was going up while sulfur trioxide concentration went up.
But I don't know what sulfur trioxide concentration means in this graph.
Maybe sulfuric acid corrosion needs water to affect to the metal? So dewpoint is a important criterion for corrosion happens?
If that's right, it's difficult to corrode while sulfur trioxide concentration goes up?
RE: What's the effect of SO3 (sulfur trioxide) on Sulfuric acid corrosion?
It's the graph about calculated sulfuric acid dew point vs. sulfur trioxide concentration in 10% water.
Not sulfur trioxide corrosion.
Plymouth Tube
You will find in various percentages.
From what I remember when we used 125 Oleum was the corrosion rate and mechanics on CS was the same as for the 96% acid.
