Tilt Up Differential Settlement Tolerances
What amount of differential settlement do you find to be the tolerable limit for typical tilt up concrete construction?  What would you have typicaly for footing loads?
RE: Tilt Up Differential Settlement Tolerances
i usually see the 1/2 to 3/4 inch tolerable differential number thrown out by structural engineers on jobs i've worked on.
4-5 klf for say a warehouse. maybe higher for other applications.
What would you use for isolated interior columns, load and settlement?
