Steel/Aluminum connection
Will painting steel and aluminum prior to fastening them together with stainless steel screws prevent a galvanic reaction? This will be used for an exterior canopy. Or should a separation tape be used. Thanks.
RE: Steel/Aluminum connection
Unless you have specific trainning in this area get the support of someone who does; At a minimum a material supplier/manufacturer, ideally an Architect.
Cheers,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
We found this easier because they usually have a different way of doing things, and just saves the RFI and back and forth, at least for us.
RC
All that is necessary for the triumph of evil is that good men do nothing.
Edmund Burke
