Check Valve vendor
Check Valve vendor
I am looking for a 3/4" ball or piston type check valve with no spring or low pressure spring(< 1 psi) with NPT or JIC connections for use in a diesel fuel application. I cant seem to find anything larger than 1/2". Does anyone out there know of any suppliers that could provide this??
RE: Check Valve vendor
http://www.muellersales.com/pdf/parker_c.pdf
Ted
