Full Tensile Capacity of Brace
I am working on a job were I am designing vertical bracing connections. The job specs. say that the bracing connections have to be designed for the full tensile capacity of the brace (Pult = RyFyAg) which is an ultimate load using LRFD. Is there any way to use this same criteria using ASD method?
RE: Full Tensile Capacity of Brace
