Problem with detailed view
When i try to insert a detail view within a detail view, the view does not show the contents within the circle (see detail view B in attached figure). It seems that the view is skewed and does not show all the edges that lie inside the circle. Has anyone ever had this problem? Is there a way to fix this?
Mike
Mike
RE: Problem with detailed view
-handleman, CSWP (The new, easy test)
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
