gauge r and r study using a laser tracker
Hi, in our workshop we use a portable measuring system called a laser tracker for component inspection and jig building. each job measured is situated at different locations around the workshop.Also each job differs greatly in size. Our inspection dept is keen to carry out a gauge r and r study to assess the tracker and operators within this workshop. being that this is a portable measuring device which can be influenced by enviromental changes would the findings be accurate if just based in on small area of the workshop. any advice would be appreciated
RE: gauge r and r study using a laser tracker
Unique setups for each job will have their own R&R. If you have multiple operators, each of them will have an influence.
As you indicate, environment will have its affect as well. If it cannot be controlled, I would recommend that it be at least monitored for temperature and humidity. Chart and track the data for an overall indication of stability. If the device is sensitive to vibration, that should be considered as well.
Overall, assuming the volumes of various parts would make it worthwhile, I would recommend using some SPC charting to take a look at the gage, at the very least for tracking your environmental factors. From there, perhaps a two level study. At the first level, multiple operators using the same setup and at the second level, the operators each setting up and running their tests individually.
How in depth you care to go depends on the available time and budget available. These studies can be expensive in terms of time spent and materials "held up" for the course of the testing. Spend a good portion of your time planning what you want/need to do so that the testing portion can run smoothly and quickly.
