Testing Hydraulic Tubing
I am involved in testing hydraulic tubing system (design pressure = 3000psi).
I have tested two sections individually.
I plan to join these two sections with JIC fittings.
Can anyone advise if I may do a "service leak test" of the system with pressure provided by the hydraulic system (ie the test pressure would be approx. 3000psi rather than 1.1 x design pressure).
djwright
djwright
RE: Testing Hydraulic Tubing
What does your contract require?
Mike Halloran
Pembroke Pines, FL, USA
