Satchell link question
I am looking for good information on designing a satchell link rear suspension. The car is a four cylinder, five speed, front engine rear drive platform. It should scale in at about 2050 lbs when done. This car should make about 300 horsepower and its intended use is tarmac hillclimbs.
Any books you can refer me to or personal input is appreciated as I am an engine builder not a suspension guy
RE: Satchell link question
Anyway, sorry, they must be mentioned in Milliken cos they aren't in the index of any of the other usual suspects.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
http://c
Photos of one system (note the orientation of the 4 locating arms painted green)
http://c
It's main advantage appears to be the ability to have good anti-squat geometry without causing roll oversteer. Is that something you need in a hill-climb car? Sounds like more of a benefit in a roadracing application.
It is a good system, within the limitations of any 4 bar setup.
But, since traction out of tight corners is your main requirement I'd have thought something a bit less compromised was indicated.
Cheers
Greg Locock
