Garage Slab Capacity to Support Brick Veneer
Hi. I am a structural engineer but don't deal with concrete. The firm I do work for has run into an inspector who is refusing to pass a garage conversion without an engineering evaluation of the ability of the slab to support the new brick veneer sitting on the edge of it where the garage door used to be. There are no building loads on it as the header above takes them out to the footings. I have seen this done many times with garage conversions and intuitively think it has got to work. But how can I prove by calculation that the garage slab can support the brick load at its edge?
mark
mark
RE: Garage Slab Capacity to Support Brick Veneer
If you are happy with the performance of the slab edge over the period it was used by cars, then it is just an engineering judgement. The brick really does not weigh much, but you could be hit for any cracks in the brick.
Expose the edge beam at the door and at the wall adjacent to the door.
If there is no change you can argue that there is no reason for the slab not to be OK.
mark
