Baffle Design
Baffle Design
I am trying to find a good source to study desing of baffle walls and shapes for waste water treatment. I want to know the kind of issues that has to be addressed while designing the shape of baffle. Can anyone help me in finding a good book or give any suggestions.
Thanks in advance!
Thanks in advance!
RE: Baffle Design
RE: Baffle Design
Do you any book that covers all or most of the applications regarding baffles? Presently looking for waste water treatment baffles design/shapes.
Bhyrav
RE: Baffle Design
Runoff
RE: Baffle Design
Thanks for your reply. I looked at Metcalf and Eddy, but they talked about the desing of the baffle system. I am looking for the shape and design required for baffle panels. I looked in Waste water engineering Treatment disposal and re-use. Is this the book you are referring to? Thanks again.
RE: Baffle Design
Are you trying to counteract the effect of a tank mizer? Are you talking about a chlorine tank? Are you talking about a chemical mizer? Are you talking aoubt a baffle in a pump wet well?
These are all different application that may need a baffle and the baffle would be different in each.
RE: Baffle Design
Thanks for your reply. I am trying to design a baffle which acts as a wall and submerged flow control devices. These can be used for chemical mixers, chlorine tank etc. As I am new to this field, I would like to learn as much as possible before coming up with a design. Thank you.
RE: Baffle Design
This article is useful and will probably answer your questions:
http://www.haywardgordon.com/documents/Baffles.pdf
Regarding "I am trying to design a baffle which acts as a wall and submerged flow control devices". Why don't you use a parshall flume as a flow control device on the outlet of the proposed tank. The flume will maintain the water level in the tank without fouling up with solids. This arrangement is commonly used on the outlet from grit tanks.
RE: Baffle Design
RE: Baffle Design
In case of a flat sheet their will not be any extra turbulence so I am trying to comeup with a curved sheet for baffles. With the information you provided I will try to determine the shape of the baffle.
Thank you.
