trying to figure the quality of an ultra high purity aluminum
Hello to you,
I would appreciate your help on that:
There is an Ultra high purity aluminum stock calimed to worth USD 200,000 / kg.
I need to verify this value...
I am told that the lower the 'alpha-particle emission rate' is - the (very much) more expensive the material is;
my question is, Any other key parameters should I check with the guys possess this material for the above purpose?
I'm attaching a (poor quality) prints.. not sure if they'll conribute ..
Thanks very much!
Thanks very much!
RE: trying to figure the quality of an ultra high purity aluminum
TTFN
http://www.tedpella.com/cressing_html/targets.html
htt
http://ww
TTFN
if I take for example:
Aluminum Target, 99.999% Al (19mm x 1.5mm) each 225.00
that's 28.5 cubic mm (that's close to 1 gr ? * * )
so this material is approx. USD 200,000 / kg
* * what would be the specific gravity of such aluminum ?
The question is: do cut N polished 1/3 gr material cost like 1/3 gram from the Raw material ? probably not..
Ultra-pure Al in "raw" form is an oxymoron. Any further processing of the material is likely to add contaminants. You can buy larger targets, which are substantially cheaper per gram.
Did you even look at the second link I gave you, which has a 4-in target that's $2700/kg?
TTFN
2. Yes I did look at the 3 of them and at each I tried to go and find anything 'closer' to the 'raw'
Appreciate your help.
in this poor quality jpg that I uploaded, anything can give an indication about the metal's quality and cost? (it's in approx. 1000 gr ingots)
Thank you!
NP
TTFN
Thanks for the help!
NP
