BEST MATERIAL SPEC FOR ROLLERS
I have an application where we are using 3-1/2" DOM steel tube to create rollers for a web handling machine. THe issue is we are "attempting" to have the roller dynamically balanced and are having issues. The RPMs are up to 3100 RPM, and in our clculations we go through 2 critical speeds. The roller is 60 " long/wide. Is DOM steel tube the best material to callout for this application?
Ray
Ray
Every once in a while the voices in my head have good ideas.
RE: BEST MATERIAL SPEC FOR ROLLERS
Don
Kansas City
Ray
Depending on how close of tolerance you need on the dynamic balancing.
scale of 1 thru 10 , 10 is hardest,
.070 oz in. = 5
.005-.020 oz in. = 10
what is your requirement?
the tubing even tho Drawn may not be close enough.
it may require centerless grinding on the O.D.?
how round are the parts, wall thickness maintained?
Try this
if you do a sample inspect, on a surface plate. place the cut DOM Tube over two precision v blocks locating on the outside diameter & Indicate the ends of the ID's, indicate over the entire od with dial indicators.
this will tell you how true it is.
we have small tubes machined from solid bar, ground & we hold .001 in oz.
post back
HTH
http://www.webexinc.com/index.html
You can centerless grind the outside, but since the process is "centerless", this doesn't really ensure that the ID is concentric with the OD. So you'll probably have to have the inside bored as well.
Don
Kansas City
STANDARD SPECIFICATIONS:
2" dia. x 0.25" wall 6061-T6 aluminum tubing machined for minimum stock removal
32 Ra finish on roll face
Dynamically balanced at 1000 FPM
O.D. and bore run out within 0.002"
Straightness over face width within the greater of 0.002" or 0.0005"/ft. of length
Low-friction bearings installed for a 0.75" dia. shaft*
*See "Shafts & Mounts" for more information.
Ray
Good to hear all is well. :/
Thanks for posting back & letting us know.
Take Care :)
