measure of friction in bearings
How can I tell a certain bearing will have lower friction then another bearing? Most manufactures dont list the coefficent of friction. Is that the value I should be looking for?
Matthew
RE: measure of friction in bearings
What you are looking for is probably a torque value for each bearing under the same conditions. Look at the Dyna Roll site and you can get a feel for this bearing parameter.
If you look further into the site you will see that this value requires some special equipment for evaluation.
http://www.dynaroll.com/catalog/pag026.htm
SolidCreative,
   What kind of bearings are you asking about, and what do you plan to do with them?
                          JHG
