NX3 pre-selection
NX3 pre-selection
Hey guys, hopefully this is an easy one. I just switched to NX5. When i was in NX3, I turned off pre-select. I was able to click thru things until I found my selection. Is that still possible in NX5. I really hate Pre-select/highlight on roll-over. I want to be able to click thru faces and bodies without having to turn things on and off, or rollthings over, just to pick it. Thanks
RE: NX3 pre-selection
If say you have multiple faces, bodies, ect. put mouse over object until the 3 dots appear next to the selection cross, click and a Quick pick dialog should open with the selectable items in a list
So you want Rollover highlighting OFF so it doesn't highlight when you move your mouse over an object? Just click it off under Preferences -> Selection.
Now, nothing will highlight UNTIL you make a mouse click on an object and Quick Pick will still appear and highlight as you move up and down the list if you waited for the 3 dots to appear.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
'Highlight Selection On Rollover' toggled ON
'Rollover Delay' set to 3
'QuickPick on Delay' toggled OFF
This way I only get pre-selection highlighting when I stop moving the cursor and wait a slight delay. I also never get the 3 dots for the QuickPick until I hold down MB1 for about a half second, this way I have direct control over WHEN QuickPick is triggered.
As for WHAT gets preselected, in NX 3 you had 3 selection MODES: Object, Feature and Component. In NX 5 you get 5 selection PRIORITIES: Feature, Face, Body, Edge/Curve and
Component. The old 'Modes' were filters where you could ONLY select the items as defined by the 'Mode'. With selection 'Priorities' everything is selectable ALL of the time, just that the items that get the top priority (highlighted first and appearing at the top of the QuickPick list) are the ones the priority is named for. This way you can always select what you wish, either directly with the cursor depending on the 'Priority' set or by QuickPick where all items are available, and within QuickPick we've added mini-filters to shorten the list of objects if it gets unmanageable.
After using NX 5 for a while, if you ever have to go back to the old 'Mode' scheme, you'll rip your hair out, at least that's my humble opinion
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
