PAC Recovery
PAC Recovery
PAC Recovery
If PAC is dosed into an open channel, what methods of recovery and treatment for re use are available?
RE: PAC Recovery
Assuming that you are talking about powdered carbon, there are not many options available. The typical dosage is 20-200 mg/l of carbon. The most common scheme is removal with a clarifier.
A second alternative is probably the use of an in-vessel membrane reactor process where the membrane functions as a clarifier. However, I have not seen an application like this.
