what's the difference between the DTEXT and MTEXT command in AUTOCAD
I read somewhere that "DTEXT allows you to add text to a drawing and see the text as it is being placed", I don't quite understand what "add text to a drawing" mean. As you can add text to a drawing use MTEXT command as well, then what's the difference?
If possible, please explain in detail :) any answer will be appreciated.
thanks all
thanks all
RE: what's the difference between the DTEXT and MTEXT command in AUTOCAD
