Oil Water Seperator Calculcations
Does anyone know a method of providing calculations for an Oil Water Seperator for a Truck Dock?
We have a trench drain which collects to a common point and then will travel through the Oil Water Seperator before it hits the outlet.
Thank you for your help!
RE: Oil Water Seperator Calculcations
The IPC states the oil separator have a minimum capacity of 6 cu ft for the first 100 sq feet of area, plus one cu ft for each additional 100 sq ft.
This requirement is for areas where vehicles are serviced, greased, reapaired, or washed, or where gasoline is dispensed. But it could be used for other areas as well.
