Background sheets
Background sheets
Background sheets
I'm using V18 of Solidedge and just created a new template for part drawings. There are previous drawings I need to use but they have their own background sheet/template. How do I change the part drawings to my template without having to re-dimension everything?
Any help greatly appreciated
RE: Background sheets
to exchange the background sheets of existing drafts there is
a program available
ChangeBackgound
it's in German but AFAIK can be switched to English language
dy
You can copy/paste all your drawing views from one draft to another ie. from old drawing into new template.
Alternatively copy/paste the info from the background sheet of your new drawing into the old ones.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Beachcombers 2nd alternative is the better of the two choices.
Open your new template,
go to the background sheet,
select all and copy.
Open the old drawing,
select all and delete,
paste.
--Scott
http://wertel.eng.pro
Actually, if file properties are different etc the first method of beachcombers can have advantages.
I decide on a case by case basis, I've probably done the second one more though.
KENAT, probably the least qualified checker you'll ever meet...
