WB and classic: Thermal gradient invalid
Hi all,
I have done a thermal transient analysis in WB and then try to read the results in ANSYS classic. Most of the results are fine except when I want to generate a thermal gradient plot on a node against time (through TimeHist Postpro). After selection of node, the minimum and maximum value in the time history variables table show an 'invalid' message.
I am not sure whether this is because of I am using WB for the modelling. Anybody out there has experience this?
Thank you in advanced.
-Ragedz-
-Ragedz-
