Unbraced Length of Arch
I am doing some preliminary design work for a building with Glu-Lam arches (this is more of a general question which could apply to steel as well). The member would be continuously laterally braced by the roof for buckling about its weak axis. But what would I use for an unbraced length for buckling about its strong axis? I have been unable to find any references with recommendations. Any help would be appreciated.
RE: Unbraced Length of Arch
You need to look up timber arch construction... I'll try to lay my hand on a design procedure.
If you have other specific questions, post again.
Good luck,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
So that means if it is fully braced about the weak-axis, I can use the full allowable compressive stress for design (not reduced for column buckling/stability effects, i.e. Cp = 1.0 for NDS design)?
There is an equation for buckling of circular rings under uniform compressive loading. Try Roark's Formulas for Stress and Strain, I believe it's in there. He might even have some information on buckling of arches, but I've not looked for it. For steel members, the buckling of a circular ring is usually not the controlling factor. Bending due to nonsymmetric loading is.
Mike McCann
MMC Engineering
