Nickel Plated Brass Adapter Quesion
Is a nickel plated brass adapter ok to use in a refinery or a petro-chemical environment?
RE: Nickel Plated Brass Adapter Quesion
Some of the most common environments would be salt spray, water, petroleum (oil, oil byproducts), detergents, solvents, textiles, UV (if outside), plastics, paints, rubber, and natural gas.
loudig
Depending on the integrity of the plate Ni is used in some fairly rough environments.
Without specific tests versus each media I would ease into using it.
-Loudig
