Autocad Viewports
Autocad Viewports
Autocad Viewports
Hello All,
I would like to know if there is a way to "Lock" the view port from showing all layers after I have created a new layer in my model.
Every time I have my view ports set & current viewport locked & I add a new layer in the model & for some reason Autocad shows "All" layer in the viewport that supposed to be locked?, why does it do this?  Is there a way to stop this from happening...
Any help would be great
Thx,
Lee H
RE: Autocad Viewports
New layers are by default visible.  You can change this when you create the layer but it would be a small effort on your part.
I think that by actually freezing a layer in my model space is what made all the viewports update to show everything...?
It should not have done that.  It does not do that for me.
use the command VPLAYER command when in layout
O.k. I will try that...
