Saving Listbox values between sessions
I am using listboxes in the calculations for a design sheet. The problem I am facing is that if the user wishes to return to the saved design sheet at a later date, the listboxes all return to their initial values. Is there some way of saving the values of the listboxes when you save the worksheet?
RE: Saving Listbox values between sessions
see todays answers in the collab http://collab.mathsoft.com/~Mathcad2000 by Richard Jackson.
case a: the data is saved as the text line in a list box and re-used (box can be hidden)
case b: the data is saved in the worksheet metadata (V13/14).
Philip
