design library features causing crash
Any time i try to add a feature from the design library, SW crashes on me.  Other users in my company don't have this problem.  Any thoughts?  The toolbox works fine.
SW 2008 Office Professional SP 4.0
Intel Xeon 3.40GHz
3 GB RAM
Windows XP SP 2
RE: design library features causing crash
Do you get an error message, or does SWx just die?
Have you tried using the copy settings wizard to get one of your coworker's settings onto your install to see if it's something to do with your settings?
If all else fails, capture an Rx video of the issue and send it to your VAR...
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
SW just closes without any messages.  I guess i'll send the RX zip file off to my VAR.  The weird part is that i recently copied my system options to my coworker's machine, and his works fine.
Adam
Intel Xeon 3.40GHz
3 GB RAM
Windows XP SP 2
I've been having random crashes/lockups on my machine too, and believe it's crashing/locking up when using the design library as well. I'll be back with details if I have them.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
I'm just a little verklempt. Talk amongst yourselves. I'll give you a topic. Pink Floyd, was neither Pink nor Floyd. Discuss!--"Coffee Talk" Mike Myers SNL
