Need help with a drawing
I have an assembly that I am trying to overlay a concept sketch on.
I made a drawing and sketched the concept on top of a cutaway view of the assembly. It looks good except the lines are not thick or highlighted, how can I get them to stand out a bit more?
RE: Need help with a drawing
Enable the "Line Format" toolbar.  Select the sketch entities of interest and change their lineweight/style/color as desired.
-handleman, CSWP (The new, easy test)
thank you very much
Ok I have another problem, when I go to save the sketch as a pdf, it cuts the sides of the sketch off and forces the PDF into a letter sized page.
How can I get it to save as a PDF with a landscape sizing?
