CUI menu modification does not change the menu list
Good Morning All:
I work in the Civil Engineering discipline. I'm running AutoCAD Civil 3D 2008.
I have customized Menus and Toolbars hundreds of times through countless editions of AutoCAD but this one is being a real *&%#$@!!!
I have tried revising the Workspace to Alphabetize the menus, as well as to remove unwanted menus from the menu list but it reverts to a standard list of menus. They are the standard ones in the Civil Design Workspace: File, Edit, View, Tools, Map, Projects, Points, Terrain, Grading, Layout, Profiles, Cross Sections, Hydrology, Pipes, Sheet Manager, Inquiry, Utilities, Window, Help (in that order) with the addition of File & Edit on the end!!
Can anybody shed some light on what I'm apparently missing and/or doing wrong?
Does anyone have an idea how to solve this dilemma?
Thanks in advance for your help on this.
