residential ac evaporator freeze on unico
I have a unico (high velocity) mini duct system with two zone dampers. When one zone is closed the anti-freeze limit switch at the cooling coil opens. The hvac contractor installed a bypass damper between the supply and return. This damper remains partially open even when both zones are open. Could this damper be the problem?
