parallel pump
parallel pump
I have 4 fixed displacement piston pumps 100 Gpm.and is driven by 4 200 HP motor.... have plumped all the pressure compensator to a relief valve which is set at 3000 psi.
All this are connected to a single pressure line.
I trying to bring all the pump with the same pressure on lineat the same time.
How do i do it
How do i do it
RE: parallel pump
The start of your cycle will be the closing of the dump valve rather than the starting of the motors.
Bill
"Why not the best?"
Jimmy Carter
RE: parallel pump
http://virtualpipeline.spaces.msn.com
"What gets us into trouble is not what we don't know, its what we know for sure" - Mark Twain
RE: parallel pump
