Nested Areas
Nested Areas
Nested Areas
I'm using MathCAD 13 at work, and I would like to know if nested areas give problems.
I create large sheets and they are flat during the design, when I go to add areas to the major topics I can't added areas to sub topics within the mayor topic.
I can get around it by using areas around the sub-topics first, then putting an area around the major topic enclosing the sub areas.
I get fatal errors sometimes.  Could this be causing them.
RE: Nested Areas
Nesting areas (along with heading numbering) has been long requested.
Acidently overlapping areas does cause problems and crashes at the moment.
Philip
