need a 3rd party pdf to dft creator
we need a 3rd party dft to pdf converter, using the full version of solid edge is out of the question and the free viewers and free 2d do not have this capability. any suggestions on what to use?
RE: need a 3rd party pdf to dft creator
I would suggest using Google to search for "PDF printer". Find one you like, install, and print your .dft documents as a PDF file from within the free SE .dft viewer.
I'm assuming here that you can print from within the viewer; I don't know this as I've never used it...
a couple examples:
http://www.bullzip.com/
http://www.cutepdf.com/
http://www.pdf995.com/
Hope this helps,
Martin Bellehumeur
KENAT, probably the least qualified checker you'll ever meet...
On FILE>PRINT>PRINT LAYOUT there is a quality setting which I usually set to highest definition.
If you can put up with the ad's you can have it as a free version.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
