split tapered bushings
Hi.
How do you remove a split tapered bushing from the hub on the shaft? There is a key in the bushing that holds the bushing and hub on the shaft in place. There is no set screw. The key cannot be removed from the front because there are little metal holds preventing the removal. There are three bolts in the back of the bushing and three bolts on the front of the hub. If you can please give step by step instructions of removal, it would be appreciated. Thanks!
RE: split tapered bushings
Russell Giuliano
h
Ted
as not to damage it
I've run across this on several occasions.
