Journal file to write part attribute
Does anyone know if there is a journal file, etc available that can automatically add a part attribute DB_PART_NO to a part file (native NX), and populate the value with the files part name?
The reason I ask is that because for deformable parts/part families (using a raw material part number) to be called up properly in a BOM, I need the BOM to read the DB_PART_NO field of the part.
We have been replicating a model from Mechanical Desktop into NX over the past 3-4 months, without the need to do any drawings (as we already had a full set of working drawings). Now it is time to do some drawings/BOMs and have dicovered that we need to add DB_PART_NO to all parts for our BOMs to work correctly.
I realise that when you import files into TeamCentre it automatically adds this, but this is not really an option at the moment.
Any help would be most appreciated.
Ross
NX5.0.4.1 WinXP SP2
SolidWorks 2007
RE: Journal file to write part attribute
I think so John. I don't have a GRIP compile license, but think i do have th eexecutable license
Ross
NX5.0.4.1 WinXP SP2
SolidWorks 2007
When would you need this by?  Is tomorrow evening too late?
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
No, not at all. That would be great thanks John.
Ross
NX5.0.4.1 WinXP SP2
SolidWorks 2007
Hi Mark, yes that worked well, many thanks. Is there any way that can be done in a batch?
Ross
NX5.0.4.1 WinXP SP2
SolidWorks 2007
Attached, as promised, is a GRIP program which will update all of the files in a specified folder per your request.
This program must be executed from a running session of NX, but you don't have to have any files open, just launch an NX session, go to File -> Execute -> Grip...
When you run the program, you will be prompted for the full path name of the folder where the NX Part files are located that you wish to update.  Include the folder's name but NOT the last "\".  The program will run until all NX Part files have been updated.
Note that I'm trying to convert this to a batch program, but so far I can't seem to get it to work properly (it's been so long since I wrote anything that ran in batch mode).  If I figure it out, I'll pass along that program as well.
John R. Baker, P.E.
NX Design
Cypress, CA
John, that worked well thank you very much. It will certainly save us many hours.
Ross
NX5.0.4.1 WinXP SP2
SolidWorks 2007
