Process Capability
Process Capability
Process Capability
Is it Correct to calculate six sigma parameters in process that are controled by a PLC.
Example i use an Oven where i steriliza ampoules, i read with dataloggers the temperature inside oven´s chamber.
Must i calculate the Cp, Cpk and others measures of capability process?
RE: Process Capability
Only if you want to keep it "in control".....
Remember, you must ensure that the reading are valid.  A major problem I see is that people blindly believe anything with a digital readout.  Just because it reports 156º, that doesn't mean it is!
Do a gage r and r before you start any great datalogging exercise.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
