portable wastewater treatment plant
Does anyone know of some sort of portable biological (secondary treatment) unit that could be used for a certain period of time (while the existing unit (trickling filter) is completly rehabilitated). The average flow is around 100,000 gpd.
Thanks in advance
Thanks in advance
RE: portable wastewater treatment plant
You might end up with the problem that the temporary solution might end up working better than what it's replacing tho. Trickling filters are old-timers by now and you might be able to replace it completely for equal or less than the cost of rehabilitation once you've rented what is probably an expensive piece of equipment.
www.bakercorp.com
