Effect of Temperature on Bronze Material Specs
I would like to know the effect of temperature on the yield and ultimate strength of bronze alloys; specifically UNS 67300 per BPS 4752... or anything in general.
RE: Effect of Temperature on Bronze Material Specs
75ksi UTS
55ksi YTS
16000ksi MofE
15% elongation
http
Hi.
Consider, too, thermal diffusivity of your alloy. As you're aware, that'll be a function of your copper content.
Is this bearing-related? If so, you should also be reviewing lead levels. Qualitatively speaking, higher lead levels result in both diminished corrosion resistance and fatigiue strength.
So, you'd have to determine highest levels of lead permissible without creating excessive wear, loss in fatigue strength or plastic deformation.
Have you you looked at improving surface performance by interspersing graphite?
Can your improvements be made through surface enhancements? If so, here's help:
<a href="htt
A big fan of Parker for years,
Good luck!
William Gunnar
http://www.IndustrialCoatingsWorld.com
"Effects of Temperature – Copper alloys are not recommended
for usage above 700°F. Hydrogen embrittlement
of most copper alloys begins at 700° F and increases
rapidly with increase in temperature. The copper–nickel
and copper–aluminum alloys are best suited for elevated
temperature usage because they have the highest resistance
to oxidation. Copper alloys remain ductile at
temperatures as low as –300°F."
