Modeling flews
Modeling flews
Hi! I try to construct a model of flaw at Patran. First i make a two domention (2D) model of flaw. In this i design a square shape and in this i make the flaw as thin brill. At the end i analyse this geometry with its loads but when i try to load the xdb file, the Patran send me a below message: "Begin: attach xdb file" and it doesn't make results.
The same behavor, it has with 3D model which i construct after.
What is it occured?
There is a special method which i can get solution at problems of flaws?
Kostas p.
What is it occured?
Kostas p.
RE: Modeling flews
RE: Modeling flews
RE: Modeling flews
i take it your using nastran.
RE: Modeling flews
RE: Modeling flews
i Sent you this simply geometry which i make. Is 2D. I want to take the field of stress where challenge the force.
At properties i have input the 2d solid type. Not shell.
Can you solute this geometry..?
Can you say me some tips which we use at these geometries?
RE: Modeling flews
Anyway, the first thing i did was to equivalance the nodes (which were needed for 55 node positions).
You also need boundary conditions which will prevent the model flying off into infinity, and failing to run, so you need to constrain to prevent rotations about the global Y axis.
There are 2 elements (81 and 83) which are collapsed and need deleting. After these then your model will run.
However, your element choice and modeling technique really does need a lot of improving. Your using the wrong types of elements and need a much better mesh to get any repsectable answers. I take it that your new to this stuff??
