why does the self-wt of a masonry wall flow triangularly?
If you are designing a lintel or bond beam supporting a CMU wall above an opening, you can design for the self-weight of only the triangular area (striking an imaginary line at 45 degrees upward and inward from the ends of the beam)...of course unless there's a vertical control joint, in which case you have to design for the self-wt of the entire rectangular area above your beam.
Anyway, my question is, why does the weight flow like this in a CMU wall? Is it the mortar? What causes the arching behavior in CMU and brick, but not in concrete, etc.?
Please don't tell me "CMU arches" :) I can see that---I am wondering why it arches.
Thanks!
Thanks!
RE: why does the self-wt of a masonry wall flow triangularly?
Basically there will be two compression struts just above each diagonal in the triangle and these will spread the load out to the supports.
It is a case of strain compatibility, the arching action is stiffer than the supporting beam so it will take the load above that point.
Just beware when you either do not have rigid supports each end or you do not have a significant amount of brick either side of the opening. In both of these two cases the arching action may not work as assumed.
The classic arch action works even without mortar, but mortar makes it more reliable and predictable. The old arches have worked without mortar, but there may have been some settlement/adjustment, but that was accepable in the short early term, considering the actual long serviceable life. Very accurate masonry units without mortar may not have required an adjustment period. - Modern arches with construction shoring and mortar have well documented performance as reflected in the pricipals behind ACI 530.
You can go crazy, with the amount of reseach on why the "arch action" works so well.
The key is to have enough height of masonry above the opening and enough masonry at each side of the arch area to resist the lateral thrust. The type and strength of the mortar is really immaterial since there is no way to relate mortar cube strengths to actual properties in place.
Dick
Mike McCann
MMC Engineering
