Another way of putting the Filters Question.
Is it possible:-
If you set the load options to 'Load Components: Specify Filter'
When you load an assembly, for NX to use a specific filter as a default, and load it, without any user interaction.
(Obviously this filter will already exist in the part)
I know this can be done manually, but I need to automate this step.
Cheers,
B
Cheers,
B
