Weight Management for Deformable Parts
Does anyone have any experience using weight management for deformable parts?  How do you get weight management to calculate weight for deformable tubing components at various lengths in an assembly?
NXdesinger
RE: Weight Management for Deformable Parts
In that case, since the actual 'deformed' component is also a body in the assembly file, you could add the weight measurement at the assembly level selecting the body of the 'deformed' component there.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
John,
To do this, would you then add the material properties (Tools/Material Properties) to the deformed body?  Just as you would the orginal body in any other component?
NXdesigner
Yes, unless they have already been inherited (something I've never actually tested).
John R. Baker, P.E.
NX Design
Cypress, CA
