Cooling Tower water quality
I am working with Electric Power Plant.I have to know about
Cooling Tower water quaility standard such as circulating water and make up water and comply with any international Std . Could anyone give me information or recommendation ? Thank a lot
RE: Cooling Tower water quality
http://hpa
Local water chemical companies can help you out, but they will want to put there equipment out there, so get a couple of opinions.
Your cooling tower selection should also tell you how much water your going to need to make-up and blow-down.
Zuccus
