ControlLogix PLC to a PanelView 600 Serial Comms Issue
Has anyone connected a ControlLogix PLC V16 to a PanelView 600 with DF1 serial??
-I have the mapping all set up in RSLogix5K.
-I have the RSView ME Enterprise comms set up as a ControlLogix process through DF1.
Apparently, you cannot use the COntrolLogix processor in RSView ME even though it's an option - you supposedly have to "fake" it by telling RSView the CNTRLX PLC is a PLC5??
Anyone had any luck getting these to play nice?
Steve
RE: ControlLogix PLC to a PanelView 600 Serial Comms Issue
You should call your local A-B distributor applications engineering folks for a fast answer.  If not that, then A-B has their own technical discussion forum on their website.  That is, IF you can actually find it in that labryinth they call a website.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
Thanks.
